- Mandalay_ParrExplorerDoes your power cord need to be plugged into your generator?
Some do and some don't. - 2chiefsRusExplorerhave you checked the breakers on the generator? should be outside on the front of the generator.
- GreenMtMommaExplorerAC in RV area not working - does not turn on at all... AC in ford can off dash working.
- 2oldmanExplorer IIWhat does 'does not work' mean?
- GreenMtMommaExplorerBook says very little - generator working - thermostat set, lights working... Generator breakers ok
Are other breakers near battery? - midnightsadieExplorer IIgot a book ?.does other lights ,light? did you check the breakers? did you check breaker at the gen set? did you set the thermostat?
