will be in vegas for 2 weeks and I know the temps are hot. My question is, we have one A/C unit. is it ok to let this unit run for the 2 weeks that we are there day and night even when we are gone fo...
Run, baby, Run! Doing anything else will leave you wishing you had! If you don't have a cool RV after the 1st day, go by Home Depot and pick up a portable A/C unit for around $200. It exhausts through a side window and will dramatically increase your cooling capacity. For future use, your coach is likely wired to add a 2nd roof A/C unit. If you think you may do this from time to time you might be happier by adding the 2nd A/C unit.
