Hello Everyone. Your forum is a great resource and I thank you in advance for all the great info. I purchased a used Beaver 2002 with the cat 330 engine. So far all is going fine, but how do yo...
Go the hardware store and buy a piece of clear plastic hose about 1 inch in diameter and 12-18 inches long. Use that piece to go into the oil filler, the other end of the hose can be attached to a funnel in which you pour your oil. It does require a method of holding the hose, funnel, and then pouring, but you will figure it out. On my rig I have to to exactly as described.
