wildtoad wrote:
emiddleb wrote:
Well, if you have (or download) the owners manual, you'll see they suggest silicon spray. There are a couple points to lube as well as removing a plug on the roof baseplate and spraying into the hole to lube the inner gears.
Owners manual
See page 4.
Do this.
You need to use silicone spray versus WD40. WD40 is a cleaner. The spray lubricates the gears and other moving parts AND lubricates some rubber seals to help prevent leaks. Not to sound like a wife, but read the manual. :W
This. Im not suure why anyone would use anything other than what the manual states.
