rgatijnet1
Aug 30, 2016Explorer III
Mr.Mark has it right. If nothing has changed in the front end, you need to look at the alignment of the rear axle in relation to the front axle.
The only other thing that I could think of would be a change in the loading with more weight being put on the right side. A simple four corner weight will tell you if that is the problem.
38,763 PostsLatest Activity: Dec 05, 2025
