PursuitInsight
Aug 12, 2017Explorer
John,
it is simple to check the cruise control harness connection, it takes more time to read this than doing it.
-open the house engine cover
-follow the plastic cable from engine throtle control, leading backwards and then forward to the front top left side
-use a light to see the speed control module
-use your fingers to push the connector in
i will not highjack your thread and create one for my own results.
the cruise is connected to:
- horn steering wheel button providing ground (mine had finally stopped working)
- brake pedal switch, cancel cruise
- master cylinder with a pressure sensor, cancels cruise
not connected to the parking brake
Addition on Sunday. after a test drive, my cruise works and i confirm:
thar the parking brake it Not cancelling or preventing the cruise
to work on my 2002 f53 lower end (frame is october 2002 and the house is 2003)
38,774 PostsLatest Activity: Apr 26, 2026
