jmcgilvary
Aug 14, 2017Explorer
Excellent post, thanks!
I did note several things in the past that were resolved (installed an new air horn) wherein a mechanic friend told me the cruise shared a ground with the horn. Fixed ground, not cruise control.
My parking break light is on all the time.
I went out and unplugged the sensor. Not sure if it is normally open or normally closed, I decided to extend the harness anyway:
Cut the wires, and checked the light: Still on (I expected as much)
Extended and reconnected them, and then realized if the sensor was bad, it would not show with it being unplugged.
Question: IS the sensor on the side of the brake fluid resolver the main brake issue light? Seems it would be, measures the differential when fluid is low, sets orange BRAKE light?
If the E Brake light is on all the time, I am now suspecting that would make the CC not work, as it appears to it that the :brake" is on?
So, maybe the switch sensor?
I will check that harness this afternoon, thanks ever so much, great post!
38,774 PostsLatest Activity: Apr 26, 2026
