jmcgilvary
Aug 15, 2017Explorer
PursuitInsight wrote:
ebrake or parking brake has a sensor on the ebrake pedal. it brakes separatly a drum and pads on the tranmission end.
not related the the real brakes or cc
the one on the master is connected to the cc. as a second secure cancel way for the cc
your ebrake issue is possibly just a sensor adjustment or the pedal spring not bringing the pedal back enough. pull on it to see
Thanks, that helps me understand.
I will try the "pull" when I get home, just to end the light being on.
I may need to see if the sensor on the Master is bad.
Ideas how to test?
I thought by disconnecting the wires, and observing as either OPEN or Shorted, the cruise ON light might work. It did not.
So, probably not the sensor?
38,774 PostsLatest Activity: Apr 26, 2026
