Jim@HiTek wrote:
I have a question about 'draining' the air system of water. How important can it be if they hide the pull cords behind the front passenger side wheel/tire? You almost have to remove the tire to get to them. Lying on the ground, I used the awning crank but couldn't tell if those drain cords moved or not. Should they hiss at me?
Advice?
If you have an AIR DRYER as 95% of DP's do, the tank drain is merely a "report card" on the condition of the air dryer. If you ever get anything but clean dry air, you are PAST DUE for servicing your air dryer.
