ScottG wrote:
CharlesinGA wrote:
ScottG wrote:
moisheh wrote:
There are diesel vehicles with hydraulic brakes and a VACUUM pump.
I thought that huge full moon was the other day. Maybe the OP is pulling our legs.
Moisheh
ALL diesel LT's have hydraulic brakes. None of them use vacuum.
Many of them have vacuum pumps but they have nothing to do with the brakes.
Without getting this thread too far sidetracked (after all, it is about air brake systems, not hydraulic systems) I gotta ask, what do you think the vacuum pump is for if its not for the brakes????? Did 'ja ever notice that big old round Bendix vacuum brake booster on all of those diesel light trucks? Something has gotta operate them. Yes, some do use a hydraulic driven booster (the Duramax had a vacuum pump but it was eventually eliminated in favor of a different boost system) My '06 Sprinter chassis for my View MH has a vacuum pump connected directly to the Bendix booster. Lots of trucks do.
Different manufacturers do use different thinking in designing their braking systems, but yes, if there is a vacuum pump, its there mostly to provide "power" for the brake booster, and possibly to provide vacuum for the enviromental system damper actuators (though most are electric nowdays).
Charles
I'm sorry Charles but your mistaken. There is no Bendix (or any other make) vacuum booster on diesel trucks.
Vacuum pumps are not strong enough to provide enough volume for brakes on trucks. The pumps are purely to provide vacuum for accessories like HVAC and operating cruise control or in some cases, exh. brakes.
They all use hydroboost systems - which are MUCH stronger than vacuum systems.
Even the light duty GM diesels from the 80's had HB systems (and they worked great).
Best regards,
Scott
Not going to beat a dead horse to death, but apparently you haven't looked under the hood on diesel trucks enough. As I noted, my Sprinter 3500 has a vac pump and Bendix branded vac booster on the master cylinder.
At various points in time, Ford, and Dodge used vac pumps and Bendix or Bendix type boosters. Don't believe me? Just do some Googling to find people selling hydro boost conversions for those vehicles. Indeed, even some gassers used hydroboost systems, probably due to a underhood space issue with the vac boosters. But yes, diesels such as the late '90's Ford Powerstrokes used vac pumps and vac boosters. Converting to the hydroboost from later Superdutys is a big discussion on some of the forums.
Charles
