golfnuts's avatar
golfnuts
air compressor
need a air compressor for a class c motor home. Do not have a lot of room. size of tires is 225/75/16 10 ply. Bought a small compress takes way to long and to noisy. need one that will do 80lbs. Maybe a cylinder type.
  • I have a 2 HP Craftsman tank less compressor. It will inflate my tires in a few minutes to 110 lbs. With 2 HP, it doesn't bog down inflating at high pressure.
  • Dewalt D55140
    9" height fits in my Class C outer storage. 1 gal tank, 135 psi.
    Good for tires And blowing out water lines for Winterizing. This is handy if you need to Winterize on the road. Same unit also sold under different branding.
    I also gave away the Big compressor since this works well.
    For tires Only, might consider a high output tank-less like the 4x4 truck guys use. Much smaller.
  • Pancake compressor. Bought a Porter Cable from Lowes on sale last spring. Liked it so much i gave away my large compressor. Now its the only thing I have
