wvabeer's avatar
wvabeer
Air dryer purge every 40 seconds
Has anyone had this problem? I've check for air leaks on the line to the reserve tank and the line to the air drier all from the governor. A new governor, rebuilt air drier replaced air line from compressor to the air dryer. I think I have it narrowed down to the air dryer needs rebuilt again as last year I rebuilt it and fixed this problem. Is this a very big deal?
  • Most likely the pressure relief valve popping off, the regulator on the compressor is bad
  • JRscooby wrote:
    First thing I would do is open the valves, make sure there is no water in tanks.
    done that no water
  • First thing I would do is open the valves, make sure there is no water in tanks.
