Executive wrote:
Hello all. I hope everyone had an enjoyable Christmas. Looking forward to the new year. To end this year, my coach decided to present me with a new problem. One that I need to fix ASAP. When the coach is idling, in drive, I am losing air pressure. Idling in gear at 5mph for a couple blocks and I will lose about 30psi. Driving at speed and the compressor keeps the air up but stopping at traffic lights and I can see the pressure begin to drop. I've blasted what fittings I have found and have located 5 small leaks which I will fix. The sixth is a pinhole in the front air tank so that will have to be replaced. None of these leaks are sufficient to cause the air pressure drop I'm experiencing. Further investigation revealed a possible culprit but I'm not sure how to proceed. With the coach idling, in gear, parking brake set, I can hear air escaping from the door air seal. I assume, (yeah, I know what that means) the air seal allows the psi to drop. What I don't know is how to trouble shoot it. So far, I've found no one that is familiar with how this seal works. I would guess there is a solenoid somewhere that controls it. Again, I assume it would have to be adjustable in order to control the psi to that seal but I could be wrong. I put a call into Monaco but I was 15th in cue so I left a voice mail and am waiting for them to call back. If anyone here who has had a similar problem and can point me in the right direction, that would be greatly appreciated. Thanks in advance....Dennis
Dennis, You may want to look into an ultrasonic leak detector. Find on Amazon or Ebay, makes finding the smallest leaks a piece of cake.
