CA Traveler wrote:
The sixth is a pinhole in the front air tank so that will have to be replaced.
Have you maintained the air dryer? Do you drain the air tanks?
Where is the leak? Have you considered welding the tank?
I would not just patch it. My son successfully patched his garage air compressor tank but that is not a safety item.
I am a bit anal about maintenance, so yes, the air dryer is replaced on schedule and I drain the tanks at least once a month although I've yet to have anything but air escape. The pinhole is at one of the original welds in the tank...someone got a little sloppy. The tank will be replaced one way or another....Dennis
