busyguy wrote:
Hi Doug
You have raised an interesting question. Maybe they do dump when the jacks are used like you say. Iwas just wanting to be able to dump them before I started to level as then I wouldn' have to raise the coach so high to get it leveled.
I have a friend who has an Alfa see ya. Will look at his to see how it is set up.
Keep the ideas coming as I really apreciate all the good info that is available on this site.
Thanks
Busyguy
Busyguy,
Ok, we may be getting somewhere with your issue. Here's a test you can do that may help you some. If you start to use your levelers, do you feel any movement in the coach, (as in sinking down) prior to any of the jacks touching the ground? Do you "HEAR" any air escaping as your hydraulic pump is working to pump up the leveling system? And finally, If you could, SAFELY, lay near the coach close enough to see the air bags as your DW starts to use the levelers and see if you can tell if they're deflating or not?
Now, once you've done any of these tests and, determine they are in fact deflating as you are using the levelers, then you might not be lifting the coach as high as you may think because the jacks and the bags are "meeting" in the middle so to speak. As the bags deflate, and the coach starts to drop in height, then the levelers "catch" that drop and start to raise the coach for leveling. Just my thoughts here.
Scott
