abzs's avatar
abzs
allison 1000 transmission
driving an Itasca 34' class A MH in KY. MH is on a workhorse chassis w/ a 8.1 engine. I am towing a Chevy Equinox up and down the hills heading for the mtns. in TN. After several hours got a alert on our lcd display saying to "check transmission temp". I slowed down and took it easy for a few miles and it went away. Is this something to be concerned about and have checked? If so what could the problem(s) be?
Any info would be appreciated!!!!!!
  • Were you bumping in and out of overdrive or did you lock it out. Constant shifting will cause what you described on steep hills, the trans keeps looking for od and trans overheats.
  • I have a similar setup with a lighter toad.
    Have not had that problem or warning.
    However, if I did, my next stop would be to my trusted Allison repair center for a checkup and diagnosis. That's just me. The Tranny is an expensive proposition to take a chance with warnings.
    Within the first two years, had the Allison serviced and the torque converter replaced under warranty.
    The Allison tech said there was a defect in the converter which they discovered during a filter/fluid check when removing the pan.
