hostage's avatar
hostage
allison 3000 filter change
got 29000 miles on the 2008 ISL cummins 425/ Allison 3000 trans
1) should a person change the AT Filters yet?
2) any one know for sure how much oil drains when the two filters are removed
thanks
  • siggyd777 wrote:
    When I changed filters on my Allison 3000 MH, 4" sump, I lost about 1.5 Quarts of ATF. Draining the ATF & filters, you need to refill 19 Quarts, then check after driving with the transmission hot,at least 140F, using the up / down buttons.
    Siggy
    thanks man that's the info I was looking for;;
    My question was
    so 1.5-2 quarts roughly? many thanks
  • When I changed filters on my Allison 3000 MH, 4" sump, I lost about 1.5 Quarts of ATF. Draining the ATF & filters, you need to refill 19 Quarts, then check after driving with the transmission hot,at least 140F, using the up / down buttons.
    Siggy
  • The first filter change is at 5000mi then 75k
    The new Allison Filter Kits P/N
    Sump Type
    Shallow 2" Filter Length 4" P/N 29558117
    Deep 4" Filter Length 6" P/N 29558118
    Here is some good info
    http://www.irv2.com/forums/f125/
    JR
  • azdryheat wrote:
    Change filter at 75,000, according to Allison.
    LINK
    thanks good reading
    look like around 2009 they switched to hi capacitys filters that are good for 75K and others before that should switch to them and then good for 75 K miles
  • MountainAir05 wrote:
    Seems well past the time as in years, that Allison has listed on their chart of 36 months for standard fluid and filters.
    If you have TES 295 that is a another chart. 20 qts. 5gal pal is cheaper.
    looking for a mileage reference;; it has syn295 oil
    was hoping someone knew the amount of fluid required
  • Seems well past the time as in years, that Allison has listed on their chart of 36 months for standard fluid and filters.
