joraz wrote:
Someone suggested to me that I add an anode to this tank
joraz wrote:
Guess I should have read the manual! I'll forgo the anode. Thanks to all.
jor
Might want to tell 'someone' that they aren't needed.....pass the info forward cause 'someone' is mistaken.
Course I'm not surprised.....
Goggle 'Atwood Anode Rod Replacement' and thousands of hits with hundreds of vendors from E-Bay, Amazon, CW etc. hocking anode rods for Atwood Water Heaters.......not to be confused with Suburbans which do use anode rods. The aftermarket (aftermarket only) Atwood rods are 1/2" diameter to fit in Atwood drain holes (Suburban are 3/4"...for a reason)
Just because an item/product is available in the aftermarket doesn't mean it is better, needed or necessary. Always check MFG. before wasting your RV Monies.
