joraz's avatar
joraz
Anode Rod for Atwood
I've got a new Atwood 10 gallon water heater in my rig. Someone suggested to me that I add an anode to this tank. I'm looking for opinions on whether this is a good idea. Thanks.
jor
  • As stated above, not needed in an Atwood. In fact the owners manual says not to use one.
  • Ozlander wrote:
    TucsonJim wrote:
    Suburban water heaters require an anode rod due to their construction (steel tank). Atwood water heaters are aluminum and do not require an anode rod. They typically have a plastic drain plug that can break when the plastic gets old and brittle. I'd suggest you pick up a spare drain plug the next time you're in an RV parts store and carry it as a spare.
    What TJ said. That's all you need.
    What TJ and Ozlander said. You do not need an anode in a new Atwood. I remember reading that the old (many years old) Atwoods used a steel tank and needed an anode but that was many, many years ago.
  • Suburban water heaters require an anode rod due to their construction (steel tank). Atwood water heaters are aluminum and do not require an anode rod. They typically have a plastic drain plug that can break when the plastic gets old and brittle. I'd suggest you pick up a spare drain plug the next time you're in an RV parts store and carry it as a spare.
  • Yes, the purpose of the anode rod is to take the corrosion rather than your tank. They're inexpensive compared to replacing your tank and easy to install and replace.
  • Do you have one now? If so, do you know when/if it was ever changed?
    Not much of a problem to change but for an upgrade not sure i would mess with it.
