Golden_HVAC
Jun 11, 2013Explorer
I agree that $46 shipping is a painful kaching!
Yes you "Should" be able to use a battery powered thermostat. The Honeywell 6000 series comes to mind. It runs on 2 AA batteries. Yet remember that if the battery is dead, the furnace will not work. So keep a extra pair around, or remember to rob the TV remote control when you need to.
Normally there is a yellow wire that energizes the cooling relay.
White is normally the furnace relay.
Another wire or two is used to power the fan on low speed and high speed. You connect the wire you selected to run the A/C fan on the G terminal. You can not run both speeds (it will melt the fan wiring) so I would select high fan speed and hook up that wire to the G terminal, the other fan wire do not connect. The furnace fan runs on it's own.
If you have a heat pump, it will have difficult wiring on it. Good luck! Yet you do not "Have" to run the heat pump, just wire it for cooling, and use the furnace by energizing the white wire with the W terminal.
The thermostat should have a
W - White wire (typically)
Y - Yellow wire cooling
G - A/C fan wire
C - common wire used in a 24 VAC (home) system only
R- input wire to the thermostat. In MY RV, the wire is red.
Have fun camping.
Fred.
G - A/C fan wire
Have fun camping.
Fred.
38,707 PostsLatest Activity: Feb 28, 2025
