Dale_Traveling
Jun 11, 2013Explorer II
The problem you will run into using a home thermostat is that is runs off of 24VAC not 12VDC. You could wire up the system using a door bell transformer to set down from 120 to 12 VAC but you won't have heat without being plugged in or with the generator running.
38,707 PostsLatest Activity: Feb 28, 2025
