  • Greydennyhawk wrote:
    Sounds like an overheat problem waiting to happen!!
    I wouldn't think that would be much of a problem. Diesel engines generally generate more heat than a gasoline engine because of the high compression.
  • If you have a diesel pusher, you could convert the engine to run on propane or CNG. Then you'd have a gas pusher :)
  • The gas pusher (aka UFO chassis by Workhorse) was introduced at the heart of the recession....-Gramps- has one...they were made Winnebago Destination is one model that was out there...in fact,I drove one at Hershey...The concept was good...the timing wasn't and it died not because it was bad, but because of the recession.
