gutfelt
Nov 16, 2017Explorer
DSDP Don wrote:
"milestock"......It's been my experience that you typically can't pull new cable as the old cable goes through places that are too small to pull more cable, or are stapled or tied down.
You might want to call Tiffin Service and see if they can tell you if the cable runs through conduit or is just snaked through along the frame.
The sat controller is about 6" wide, by 1.5" tall and about 5" deep. To save space, I made a "U" shaped bracket and attached it to the ceiling of the entertainment cabinet where there was unused space.
Lastly, the new sat comes with a cable cover. If you have to run cable along the roof and drill through, you'll have a cover for it. Whenever I have to drill through the roof, I always do my measuring and drill from the inside out if possible. If you hit the frame or something else, you don't have an usable hole in the roof.
that's why there is no need to pull new coax waste of time and the way tiffin installs coax and uses zip ties and tangles things etc
just use the still good existing coax
