Billinwoodland's avatar
Jul 16, 2021
Winegard 360 replacement
Hi folks. I have a winegard 360, not the 360+, just straight 360. It looks like I need to replace it. What would the best replacement be that would stay in the same footprint? In my class A, I had a directional crank up that did a great job for years. I realize these omnis can’t perform like that, but what are my options? BTW, this is for an ORV TT.
Thanks
Bill
  • The Rayzar automatic has 2 TV outputs and works great on both TV's. You could also add a splitter to power 3 or 4 if necessary.
    The dome on the roof has 1 coax output to the power supply input and 2 outputs for the TV's.
  • Just looked at the Rayzar. Max receiver capability of one? Does that mean only one TV can receive/tune the input and any other TV's connected can only view the channel that the primary TV is on?
    Not sure I like that. We have two TV's in our RV and do have occasions to use both.
    Mike
  • I had the Batwing on my previous coach and was disappointed that my new coach had the Rayzar Automatic. However, I have been very happy with this antenna compared to the Batwing. Is it as good? No, but it's pretty dang good for a dome antenna and I don't have to worry about the wind or about remembering to stow it.
    I did change the roof setup to include the mount that raises the antenna about 12" above the roof (less interference from the A/C units). It is a directional antenna with a rotating antenna inside the dome so it performs substantially better than any of the omni-directional antennas. You know.....equally bad in all directions......
  • wildtoad wrote:
    You have any objections to installing a new Winegard Sensar IV (aka Batwing) along with the newer booster/control panel? It’s still the best overall performer.
    Hoping to stay with the same footprint without drilling through the roof/ceiling. But that’s what i had in my class A, good performance.
    Thanks
  • You have any objections to installing a new Winegard Sensar IV (aka Batwing) along with the newer booster/control panel? It’s still the best overall performer.
  • I replaced our damaged antenna with a new Winegard 360.
    https://www.amazon.com/gp/product/B07NBWDRT6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
