- wearenhExplorer:: sigh ::
anyone, anyone?..... Bueller?
pros/cons: Flow through vs Non
. - k9-kenoExplorerMy look on it is a safety addition. And the place I'm going to need it most is my tow trailer. As far as how long they last the company puts a nice warranty on the item and they give you free batteries for life. As far as the dually issue I have the long bent semi circle valve stem so i'll be fine. An easy way to tell if the unit is not working would be to take a tire pressure with a gauge then put the monitor on and ifs not within a pound or two you know its not working.
- pnicholsExplorer III guess I can't quite understand the need for these ... especially on at least a small Class C where the weight is such that a failed dual tire does not overload the remaining tire enough so as to immediately blow it out. :h
You could definitely feel a front tire going soft ... just like on any vehicle.
As for one of the tires in the rear dually sets going soft on a small Class C, I had one in a rear dually lose pressure and I could definitely feel it ... as the remaining tire in the dual set then became over-loaded seriously enough (but not enough to cause it to fail suddenly) such that the rear of the Class C begins to feel real "wobbly" or "squishy" and not right.
Besides .... how do you fit them onto the tire stems of the inner tire of dual sets without fist installing those special metal tire stems that are long and bent in almost a half-circle so as to come out through the rim-hole to face directly outwards?
Also how many years do they last such that they're actually working (... and you knowing that they're working) before replacement, and how often do you have to replace each of the 6 batteries in the tire sender units?
As for having them on the tires on something being towed ... that's a different story and definitely a safety addition, IMHO. - wearenhExplorerI am going to bite the bullet and get the TST 507 system, for the 6 wheels of the motorhome, plus the 4 wheels of the trailer.
I understand that it is unlikely that the flow through sensors will fit under the wheel simulators in the front, and so I will get the standard ones for there.
My question is, is there a compelling reason to get the flow through or standard sensors on the other wheels... and if not a compelling reason, any pro & cons for each type? - k9-kenoExplorerBought the Tire Minder TM66 series. When it gets here anyone have any ideas on where to put the Booster that comes with it?? It says half way from monitor and the last transmitter. I was thinking right at the camper door entrance my coach battery is right there and it needs to be hard wired to 12v. Any other suggestions or do you think that will be far enough back I will have sensors on my 2 wheel trailer. Thanks RV is 31ft Class C
- k9-kenoExplorerWow guys thanks for the great feedback. I'm ordering them no doubt!!
- wearenhExplorerwhat are the advantages / disadvantages of the flow through vs normal style on the TST ?
TIA - Butch50Explorer
Golden_HVAC wrote:
Tire Pressure Safety devices have been mandated on new vehicles for many years! I think that they started in 2002 or so.. .
They are a great device!
Fred.
They are only mandated on 3/4 ton and below vehicles. They are not mandated on 1 ton or larger vehicles. My 2014 MB 3500 chassis for my class c did not have any on it. My 2013 3500 Ram 3500 dually did not have any TPMS on it either. - kendall69ExplorerTire monitors are probably one of the best tools anyone in an RV, trailer should own.
I on my duallies before I had a monitor I had TWO inner flats, and I never knew it, till I pulled in for fuel and did a visual inspection of the rug.
I could have been driving a hundred miles or two blocks with those flats, no way of knowing without a monitor. - Golden_HVACExplorerTire Pressure Safety devices have been mandated on new vehicles for many years! I think that they started in 2002 or so.. .
Fred.
38,738 PostsLatest Activity: Jul 26, 2025
