I don't know how "Unlimited" the heat is, but it has either a 45,000 or 60,000 Btu heat input from the diesel boiler, that works out to heating about 1.5 GPM from 50F to 140F. The Aqua Hot needs to start out warm to keep up. The built in tank will cool down a bit with use, but still stay above 110F when a normal shower is done.
Fuel usage is another thing. 1 gallon of propane is about 95,000 Btu's while diesel is closer to 135,000 Btu's. My guess is a normal propane burner is about 80% efficient, while a typical diesel boiler is only about 75% efficient. So the diesel one is going to cost less per 100,000 Btu's of heat in most areas.
There is also a typical electric back up for the Aqua Heat, so you can run a 2,000 - 4,000 watt electric element (depending on model and if the RV manufacture wanted to install a 120 or 240 volt element) to warm the tank over a long time. Typically they warm 10 gallons of anti-freeze, and then there is a hot water coil that the domestic water goes through this heated (160 - 180F) tank and it will instantly warm the domestic water to 140 - 160F, then cool it with a mixing valve on the outlet to the desired 120F outlet water temp.
Many systems also include a hot water loop for the engine too. So a 3/4" heater hose line from the diesel engine will go through the Aqua Hot tank, and warm it to the engine running temp (up to about 200F) and also because the engine starts out cold, the 140F tank temp will preheat the engine quickly, then the engine will start supplying heat to the Aqua Hot after a few minutes. So with that option, you have unlimited free hot water while on the road, and about 15 gallons just after you park. Many times this allows you to not turn on the burner at all, if you are not running the furnace and don't need much hot water.
Fred.
