freestoneangler's avatar
Dec 08, 2013
Aqua Hot Systems
My neighbor's Monaco has an Aqua Hot water heating system and he was showing and telling me how efficient these are. I had not heard about them until then and did a little i-search about them. Seems like only the high end coaches have these...but perhaps other on-demand systems are as good? He mentioned that it provides heat for the coach as well and is very cost efficient.
Can the AH systems be installed in coaches not having them and are they worth the $$?
Thanks
  • As noted above, it's a great system, but I don't see how you could add it to an RV. The routing of fuel lines and radiator lines to each outlet would be major surgery to an all ready built RV. Also, the hardware takes up one entire basement compartment.
    It does provide unlimited hot water and heat.
    http://www.aquahot.com/Products.aspx
  • They are very expensive by the time you purchase it and pay to have it installed. If you were in the market for another coach, I would say find one with it. We love ours in our Country Coach. Continuous hot water and hydronic heating keeps the coach nice and warm. Runs on diesel. We still love it although we have had several major repairs done on it. For more info check out: www.rvhydronicheaterrepair.com Roger Berke might be albe to provide more info. You can also call Aqua Hot Sales for pricing. Be sure to be sitting down. They also now have an LP model.
  • Adding a Hydronic system (that is what a Aqua Hot system is called), is NOT very cost efficient to a RV that does not have one. You HAVE to have a Diesel, there are LP systems, but Diesel is more cost efficient. You have to run the Zone radiator water lines thru-out the RV, and run the Diesel lines and find a place to mount the unit. IF you have slide rooms, then running the Radiator water lines is a lot more difficult and expensive. This is NOT a DYI type job. The cost just for the system(no labor) can run anywhere from $6000 to $12000 depending on the system and size of RV. Then you have the labor and the misc parts (water lines and fittings and such). It is a very nice system to have. Doug
