hottubkid wrote:
dieharder wrote:
Sorry, but I'm seeing a lot of poor attitudes here behind the wheel of an RV.
Regardless of what the driver is doing in the fast lane, you DO NOT have right of way when changing lanes... they do. They do not have to give way to you, or "let" you in. Idiots force the issue as they don't want to lose momentum... well, the other driver doesn't want to lose momentum by getting stuck behind a billboard when they have the right of way.
And people wonder why sometimes RV drivers get a bad rap or people think that we should absolutely have to get a special license to drive one.
Just maybe A person just doesn't want put it into reverse at a merge. Many times people just won't let you take your turn so you move over slowly and usually they let you in. Look at the truck drivers they have to do it also
It doesn't matter what a person wants. When you don't have right of way, you don't have right of way, whether you want it or not. Try to press the issue if you want, as long as you understand that, if there is a collision because the person not letting you in is just as stubborn as you are, you are the one switching lanes so you are the one at fault. Forcing someone to let you in is aggressive driving... aggressive driving in a 20000+lb machine is just not smart.
