Newbie question. We were doing spring cleaning getting ready for summer use. When I used auto leveling only 3 levelers extended. If I did it manually all four would extend. My question is if the unit ...
Yes all 4 should deploy when using auto level. Since the fourth jack WILL go down in manual mode it might be a bad pressure switch at the fourth jack. Very easy to check. Also, welcome to the forum & please do add a signature so everyone can see what you have for more accurate help info.
