I have a 1994 Fleetwood Southwind Storm 28ft with a 454 TBI (4L80E) and I'd like to confirm the fan (1) that is mounted on the front of the A/C condenser is working or or not. I don't recall ever seei...
I believe that fan is for your radiator and it should come on when the water temperature reaches a set amount. Connect the fan directly to 12 volts. If it does not work replace the fan. If it does work trace the circuit back to find the fault.
