- loggenrockExplorer6 pieces of 2x8x18 work just fine for me! I can buy a lot of wood for what levelers cost! And agree that scissor "stabilizers" are NOT levelers!!! ST
- bertibleExplorerHi,
A Newbie to this forum, my wife and I just having bought an 08 LTV Libero to replace our Rialta. I thought I'd post to this older thread since one of the first things I'm exploring is levelers. In my experience, the plastic ones break easily on gravel or rough ground, and I really hate carrying a selection of planks around. I had scissor jacks on the rear of my Rialta, and they worked fine but then that's only an 8000 lb vehicle.
One problem with the Libero, not sure if other B+'s too, is that even on level ground it "leans" forward. That means I'll have to level almost 100% of the time, unless I happen to be aimed up a slope. I will not be spending $4000 on hydraulic jacks, so I think I'm stuck with either 6500-7500lb scissor jacks, or carrying 2-4 bottle jacks around. Does anyone have similar experience with a forward leaning B+? To be clear, my fridge works fine, it's my beer sliding off the kitchen table that I can't abide by!
Regards,
Gary
Delta, BC
08 Leisure Travel Van Libero - gmctoymanExplorerI've had 2 Lazy Daze that I had Big Foot jacks installed on. Why Big Foot you may ask....I had a small class A with HWH kick up jacks prior to the LD. As said earlier, PITA.
- j-dExplorer IIWe've had two Class C's with HWH Kick Down Jacks. I don't like kick down for two reasons:
1. Because of their pivots, they don't support as solidly as direct.
2. They often want to extend before kicking to vertical, then may retract without folding.
Problems with Jacks on a Class C:
1. The frame is narrow, so raising one side also raises the other side.
2. If the Class C is short, raising the rear also raises the front.
This can result in the coach being raised higher to reach level than it would be if jacks were nearer the sides/ends/corners, or if the coach is simply driven onto blocks.
I usually drive ours onto blocks. Easier to place blocks at the wheels than fish around way under trying to get a jack to go vertical.
Part of the goal of jacks is to stabilize. Again, the tight pattern the jacks have to be in with a Class C chassis reduces the stabilizing effect. Upgraded Sway Bars 1-3/8" front and 1-1/2" rear did more for stability than jacks did. - bob_nestorExplorer III
midnightsadie wrote:
leisure travel van has them .
Not really, they have an option for two stabilizers which are not to be used to level the unit. At least that's what my owner's manual indicates and what the dealer told me when I bought it. - SoloExplorerWhen we owned our previous Class C, I installed the Big Fool Leveling System on our Winnebago 23D Aspect. This can be a do-it-your-self project if you have moderate skills and the tools. We thoroughly enjoyed the convenience and stability of hydraulic leveling.
Perhaps do not limit yourself to just looking at motorhomes that already have levelers installed. Check out the various vendors and see what their product will accommodate. - ron_dittmerExplorer IIIMany Phoenix Cruisers are running around with levelers. It is an option offered and popularly chosen. New or used PCs, levelers are common on them. We elected not to get the automatic levelers of which I have mixed feelings about. The decision not to get them was primarily about the cost.
- PopsExplorerWe bought a used 2007 Aspect without, and had HWH (straight action) installed. Sold it, and bought a used 2012 Cambria that had HWH (straight action) already on. Wood not have a RV without levelers, and have heard of problems with kick down action, that I would be sure straight action can be installed if not already on.
- RDJeffExplorerSunseeker 2430S has them as an option, but most roll out of the factory with them.
- midnightsadieExplorer IIleisure travel van has them .
38,774 PostsLatest Activity: Apr 26, 2026
