USMC46's avatar
USMC46
Back Up Alarm Quit
Took my coach out today (been parked for a couple months) and I noticed the back up alarm is not working. Any "check this first" recommendations ? Will first try to locate any fuses to check first obviouslly. Thanks.
  • Check the connector where the alarm is hook up to wire harness. If OK then disconnect one wire. Hook up 12 volts to the hot side of alarm and then the ground wire from the battery to the ground wire on the alarm if works then check your connectors.
