jyrostng's avatar
jyrostng
Balancing tires on bent steel rims?
I've had more experience than I EVER wanted on this subject but didn't see much in a site search.
A electronic balancer using lead, can show a perfect balance on a bent rim, however, if you were to place that rim on a static bubble balancer you would see that the tire wasn't balanced because the machine compensated for the bent rim by making the tire out of balance.
One bent rim on the front, you may not notice much but a steady vibration. Two bent rims on the front will cause the vibration to come and go as you travel down the road. The rims always rotate at slightly different speed. As the bend opposes and counteracts each other the vibration comes and goes gradually, you can feel it in the wheel.
  • For most of my driving life, I've always checked the rims simply by rolling them on a flat cement floor and watching them roll away. A true rim will roll straight and true, while a bad rim will wobble. Have been doing this for so long, can't even remember what caused me to do it in the first place. :)
    Did you also have excessive tire wear? And an odd pattern to tire wear?
