dcbrewer wrote:
creeper wrote:
Kayteg1 wrote:
Beads will give you some noise at low speeds and they don't affect seal. Depends how that can bother you.
If you plan to keep the coach for long years, google Centramatic
X2 on the centramatics. I've seen some horrors with the beads.
Go with what the truckers use.
Will the centramatics work on the back, will be putting new tires on the back next month, I called about the ones for the front, they didn't have the ones for 8 lug, so I went with the beads.
Yes they go in between the duals. Not sure what your application is , but they do make centramatcis for 8 lugs.
