WILDEBILL308 wrote:
The facts behind this not theory are the cold engine will not burn all the fuel and it will wash down the cylinder walls(creating excessive wear)and contaminate/dilute the engine oil.
I'm glad you brought this up because I really don't understand how to avoid this at all. How do you get your engine warm without first having a cold engine that's burning fuel inefficiently? This makes no sense and it's a catch 21. If I read the comment correctly, a cold engine at idle will burn inefficiently and will wash down the cylinder. The cure is a warm engine, but to get to the warm engine, you need to burn fuel inefficiently with a cold engine.
I guess what I'm saying is that no matter what you do, your engine is going to be cold for a certain period of time and there is nothing you can do about that except to avoid starting and stopping your motor to let it cool down too often. You can't let it idle either because Cummins says that's the worse thing you can do to an engine.
But here's what Cummins told me directly. My engine has a warm up protection feature that won't allow me to fast idle or use the throttle until the engine is ready to perform and everything is up to pressure and temperature to prevent harm. This is what's coming directly from Cummins. This afternoon, I spoke to the tech myself to understand this. Once the engine is warmed up, the engine should be in fast idle when parked.
So the two worse things you can do to your engine are 1) start it cold and 2) let it idle. Talk about confusing.
