Pirate wrote:
tropical36 wrote:
cdl2 wrote:
I got the bolts & nuts from Blue Ox, & finally removed the grill cover & the bumper cover.
The left side(drivers side) of the base plate is bent down.
I tied to push it up & get the holes to line up.
No luck with that.
A new base plate is $430.
Ya gotta be kidding me. It's bent and they actually have their hand out for $430, when they should be giving you the #430, so you can buy something worth having. Am I just imagining things or is it actually true of most all tow bar and base plate failures, I've read about, involve Blue Ox?
And then, I keep hearing that they are such a good company, because they stand by their product and will readily replace defective items. HELLO!.....and having a bullet proof product is what one should be looking for, not one that repeatedly fails and gets replaced with the exact same part.
BLue Ox makes great products. Why should they replace this due to install error? I've been here for years and can count on one hand (maybe) the number of BLue Ox failures.
And how many DEMCO or other brand failures, have you heard of and wouldn't begin to know, how you could possibly bend mine? Even one, is one too many and especially if it might be yours. Also, what's with this long bar that I see on a Blue Ox and one that must be stored somewhere, if you don't want to be carrying it around on the front of your toad?
As for having a toad with a frame, most certainly if you can and with mine, it doesn't just bolt to the frame, but is in behind the bumper plates, before being bolted, so technically, even with broken bolts it can't just pull off straightaway and with side bolts, as well it can't come out from behind the frame plates.
