wilcat1's avatar
wilcat1
Basement A/C Blower
I have an 02 Winnebago with 6535A871 basement A/C. The blower & A/C worked well until the blower just stopped. Blower does not run or make a sound even in manual mode, but still draws ~7 amps low speed. Does this sound like I need a new blower motor? Blower motor was replaced in 2010.
Thanks
  • This manual should help you. If right download and save it.
    http://www.rvcomfort.com/pdf_documents/1976323_copy8.pdf
  • Sounds like the next step is pulling the unit out?? Is RV Products the best place for parts?
    Thanks
  • Before you spend a lot of money on a motor, check the capacitors. A friend of mine had the same Winibago you have I think and the tech replaced the motor and then found out it was only the capacitor.
  • Yep it sounds to me that the ac is trying to work and it just can't.
    Ron
