discovery4us
Sep 17, 2019Explorer
I have the same and yes cutting a hole in the door is the easiest way. I have found that if I cut the two sides (top and bottom) about 6 inches in from the frame and then cut the frame side right along the edge of the trim about 4 inches I can use the uncut side as a hinge. Fold the piece back replace the latch and then push the flap back.
I then take old license plates from states we have visited and using very short screws attach the plate over the flap I cut to hide it.
Also I found that a sharp exacto knife or one of the razor blade knives from the big box stores works best for the cuts.
38,782 PostsLatest Activity: Sep 19, 2026
