PCarnathan
Sep 17, 2019Explorer
Is at least one door operable? It seems you should be able to climb in one door and crawl around inside to open the doors from the inside. Anything's better than cutting up your door(s)!
On our 2009 Mandalay 43A the little cable that connects the outside door handle to the latch mechanism broke. I had to climb in another door, open the offending door from the inside, then replace the little cable.
Good luck - It's a project no matter what!
Pat in Menifee, CA
Pat in Menifee, CA
38,782 PostsLatest Activity: Sep 20, 2026
