Gundog
May 17, 2020Explorer II
A picture of what you are working on would really help. I replaced several of mine on my 05 Fleetwood expedition. I bought them off ebay you need to check the bolt spacing on them they make a few different models that in pictures look the same but the bolt spacing is different.
I also moved some of the latch bars because they did not line up well I am not sure if things shifted over time or they just did a lousy job installing them at the factory. Spray them with lube occasionally that also makes a big difference. I also don't just slam them closed I close them and lift the handle then give them a little nudge while lifting the handle if they don't latch good.
38,782 PostsLatest Activity: Sep 19, 2026
