BigDaddy1951
Oct 15, 2019Explorer
Basement Heat Pump
Help! For three days we ran our Coleman heat pump on heat with no issues. We moved to a new location yesterday. Last night the heat pump made so much noise we switched to gas. This has happened before at other campsites. I use a surge protector that shows over and low voltage. Lights all green. Using 50 amps. Need advice. Would a lower voltage cause starting/running issues? I think my protector won’t shut off until about 100 volts. Air conditioning works fine any time. Confused. Thanks in advance.
