- J-RoosterExplorer
427435 wrote:
X-2 this is how mine works!chuckftboy wrote:
one time every year the coils should be inspected and cleaned if needed.
the condensate pan should be flushed with clean water.
all elecrtical connections should be checked for tightness
check the fan blades for cracks or loose rivits. clean them if needed
there are some steel parts that if showing signs of rust should be wire brushed and touched up with rustolium paint
I'm not sure there is a condensate pan on a basement air----condensate water just falls on the ground. - Wizard_1946ExplorerX2 on checking the rubber drain. It has a rubber tab on the bottom, just wiggle the tab back and forth.
- RCtimeExplorer
correct Mark
Just make sure the rubber drain is not plugged. - 427435Explorer
I'm not sure there is a condensate pan on a basement air----condensate water just falls on the ground. - chuckftboyExplorerone time every year the coils should be inspected and cleaned if needed.
there are some steel parts that if showing signs of rust should be wire brushed and touched up with rustolium paint - maanpaontheroadExplorerKeep air passage clear and clean outside grill free from bugs etc.
38,769 PostsLatest Activity: Mar 31, 2026
