howdy35's avatar
howdy35
Explorer II
Jun 14, 2019
Batteries not charging {Resolved}
I have a 1999 National Tradewinds with a Heart Freedom 20D inverter which doesn't charge the house batteries. It has power to it but does not seem to be powered up. I'm wondering if there is a fuse inside on the input side that might be blown. Ideas? Thanks Arnold
Thanks for all the help on my problem and found my inverter was kaput. Since parts are no longer available for one that old, I bought a new Xantrex and controller. Will have it installed by local tech. As you all know, a very expensive fix, but necessary.
  • I have verified the inverter has no output and will tomorrow take it apart and determine that the pins that hold the boards together are in place. Saw that on youtube. Checked PPL on new Xantrex units and they are on sale until the 21st. One has a single output 100 watt and the other has a dual output 100 watt. Not sure which would be the one to get. Thoughts? Also the remote they show looks exaxtly like the one I have but "Horsedoc" says I need a new remote and new wire to it. I see running the wire as a definite problem. Open to suggestions. Thanks for all your help.. Will keep you posted as to the results.w
