HavingProblems7's avatar
Apr 24, 2017
Batteries Not Charging
House batteries not charging when on shore power,generator running,vechicle running
Monitor panel indicate 12.2 Unable to charge
Checked output at converter 13.7
Recently new batteries
All connections solid all cables good shape
Checked each side of 50 amp breaker bottom of battery box
Each side 12.2
Shouldn't the voltage reading at this breaker read the same as output at converter?????13.7??????
does this indicate faulty circuit breaker since I did not get a reading of 13.7????
Or does the battery disconnect solenoid have anything to do with the 12.2 reading I got at the breaker
Not sure based on above if I should replace breaker or ?????
Please help
if you know based on above
thanks
Ted
