sgordon_lazydaz's avatar
Sep 06, 2021
Batteries won't hold charge - need help
Hi All,
Newbie here so please excuse any ignorance. I have a 1992 class c Lazy Daze with a Chevrolet G30 cab.
I purchase her in March and drove every week/weekend with no problems for about 3-4 months. Went to go move her one day and both car battery and house battery were completely dead. Discovered I had left a small fan on for two days (oops) so it made sense. I replaced both batteries and made sure nothing else had been left on. Drove around for a couple days, then- bam - wouldn't start again. Both batteries dead- this time nothing was left on and nothing was draining power. Had a mechanic come out and alternator was reading as dead so I had the alternator replaced and once again replaced both batteries- started up no problem. Next day I drove her for about 3 hours, still no problems. Day after that, both batteries dead again. After doing some research I discovered the purpose of the isolator. So, my question to you all is- do we think if I replace the isolator (seems easy enough to replace myself) that this will solve the problem? Or do we think it's necessary to have it towed to an RV mechanic? I'm in a bit of a tight spot as I'm in the process of moving into her full time and leaving a failing relationship so will take any help I can get to have this fixed asap.
I've gone ahead and ordered a new isolator (same as the current one installed - diode) that will arrive tomorrow. I will try and replace my car battery though Autozone warranty for the 4th?? time but not sure if they will give me another within the warranty.
Please help!
  • Tank heaters or short somewhere or light in one of your storage compartments.
  • Thanks so much for the reply, Gary. Any idea what could be on? Something that may not be obvious like a fan or light- I'm not sure what to look for. Yes, I have access to a multimeter to check voltage. Voltage on car battery is reading under 12v. Since I cant start the engine due to dead battery, I'm not able to read voltage coming from current isolator. I imagine I need to replace the battery in order to move forward with trouble shooting?
    Thanks again!
  • It's easy to replace the isolator, if the both batteries are dead that quick something is drawing power all the time. Check and make sure nothing is on. Do you have a volt meter? If you do you can measure how many amps are being drawn from each battery, leave wires disconnected and isolated at the isolator so you can check each battery separately. You have something on, likely on the house side.
  • Read the warranty closely and take them back if there are no specific exclusions. Not what they say…it’s what they wrote.
