sssoooExplorerAug 31, 2019Battery’s not chargingMy 2018 bounder is not charging the house batteries while plugged into electric,it it just 15 amp but it should still charge I would think? Help Scott
pianotunaNomad IIIAug 31, 2019Since when you changed the battery out the lights were on, that narrows the issue to the charging.Do you know what converter you have (battery charge)?Have you checked the shore power outlet to see if it has power?Have you checked a 120 volt outlet inside the RV (use a lamp)?Have you checked the reverse polarity fuses on the converter? (don't just look at them, use a meter or continuity checker)
Related ContentBattery Chargingchassis battery charge ?Charging House BatteriesLithium Battery Charging SystemHouse Battery charging
