- eric1514ExplorerAs the post above says find the isolator. If you have a starting boost switch up front, listen for the click when you press it. That's the solenoid you're looking for.
- wolfe10ExplorerTrace the large-gauge wire from the alternator B+ terminal. It will go to a battery isolator.
It could be a DIODE-BASED isolator or SOLENOID-BASED isolator. You need to verify charging voltage to it from the alternator and charge voltage out to the coach (house) battery bank. - 1492ModeratorMoved from Forum Technical Support
38,706 PostsLatest Activity: Dec 02, 2016
