kidkasha
Oct 22, 2016Explorer
Battery Chne
1999 Fleetwood Discovery. Is it possible to chancy 4 6 volt batteries the six volt batteries to 2 12 volt batteries? Has anyone done this successfully, and what are there any issues.
pslocum wrote:
http://www.rvsolarconnection.com/batteries/12-volt-verses-6-volt-batteries.htm
No problem and with our coach, it originally came with 4 12v AGM Group 24 batteries. Dealer for previous owner, changed them out to 4 6v wet cells. I put them back to original specs., although, not so sure if having used 4 6v AGM's would have provided more power or not. Depending on the sizes and space available actually and it's just a matter of changing the series/parallel connections to straight parallel. Naturally, two 3/0 jumpers got lost in the process, so had to make those up to complete the install and found out that large crimp on lugs aren't readily available, unless from a electrical distribution house. At least not from Home Depot and the like.
If in doubt with the connections, seek help and/or check the output voltage before connecting up the last lead, which should be your neg. ground.
In my case, I have quite a few neg grounds returning and quite a few plus pos. going out, as well.
pslocum wrote:
Yes you can hook 2, 6V batteries together in series and the second together also in series and then the two sets of series in parallel so this way you get 12v and the higher amperage by doing it this way.
Series is + to - and -to + for each of the two sets of 6V batteries then to parallel them you go + from one to + of the other bank and - of one to - of the other then to tie in to the system now go + from one bank and - from the other into the system. Taking the + from one bank (series) and negative from the other insures that all four charge equally.
