toyotaspeed90
May 22, 2013Explorer
Battery Isolator - doing exactly what it should shouldn't?
So this is a relatively new vehicle to me. The wiring is somewhat nightmare'ish... both from the factory and from what others have done.
1984 E350 Fleetwood Jamboree.
2 batteries, an isolator, and 2 solenoids.
Battery on the passenger side appears to be mainly a starting battery for the engine. This is a standard battery for starting. It runs directly off to the starter solenoid and has 2 other wiring connectors on that same post as well (guessing mostly for the chasis needs).
Battery on the drivers side, just replaced, seems to be mainly for the 'house' and the generator. This is a deep cycle battery.
The alternator feeds directly into the isolator.
The isolator is a 3 post. 1 wire feeds to a solenoid on the passenger side. The other feeds into a harness, with a quick look can't tell where too.
The solenoid on the passenger side, on the same post of the solenoid that the isolator is connected to, feeds off to the drivers side battery post.
The generator is wired directly to the deep cycle battery (driver side)
When the engine is running, generator off:
14.4V is read at the center post of the isolator and at the starting battery.
12.28v is read at the other post of the isolator and at the deep cycle battery.
Generator running, engine is of:
13.8v is read at the deep cycle battery
12.(something)v is read at the starting battery
So - in looking online this isn't that atypical of a set up (solenoid and isolator)... I've read that there should be 14.4 on both sides when the engine is running.... but have also read that the purpose of the isolator is to keep the deep cycle separate from the starting battery in the event the deep cycle has voltage spikes and/or running it too low - so you can still start the engine.
So, as the title says.... is my isolator doing exactly what it should be doing or exactly what it shouldn't be doing?
