Another woman here and there is no man in our family and we own 3 campers, a golf cart, and a boat to keep running!
How do you know "no charging happened"? Did you test it with a tester or by trying to use the lights or something? Could it be that the battery charged but your battery disconnect switch is open?
It sounds like you are using an external charger and not the one in the charger/converter in the camper. Assuming this is correct...Are you sure you connected the charger properly? Red is + and black is -. To charge, you match red to red and black to black. Assuming this is not the case and you had the camper plugged in to shore power for 24 hours, did the lights work while the camper was plugged in?
I hope these questions help! I am subscribing to the thread but you can also message me for follow up. I try checking the forum each evening.
